Engine Fiat Tipo 1,6
simemk
Beitrag von simemk »
Tolle Maschine-
Daywalker
Beitrag von Daywalker »
oh ja ,
wenn ich das Geld über hätte,würde ich den Motor sofort kaufen :roll:
simemk
simemk
NEW 1,6 engine( 86,40) all parts lightened balanced , installed head with new big valves 40/35 mm 7mm steam from 21-4N steel , bronze guides , installed with new cam box, new cam racing or rally -option , new lifters shimmed , installed adj cam pulley and cam belt -engine is complete , On beck is lightened balanced flywheel 200mm ( or if wished 180mm )
with engine go new Magneti M ... distributor or( used MM with digiplex for installed on cam box complete with electronic box), all PK ot tooted alloy pulleys with new water pump and belt go on,with engine go and new slide throat body 40mm with trumpets ( for kugelfischer or El injectors)
engine is with 11,2: 1 static compression for use pump 98/100 octane gas
delivery DHL cargo in wood box
complete with DHL 4900 euro
