Racing SOHC heads....
ACHTUNG: Bitte nutzt Euren eigenen Bilder-Server für kommerzielle Angebote.
simemk
Beitrag von simemk »
For sale racing big valves head 40/35 mm ,6mm stem , racing valve springs,Ti retainers ,slide throat body , kugel-prepared cone.... complete or separate ...
or heads whit 7mm valve stem 40/35 .... http://simefiatpower.tripod.com/
Hello Sime,
do you also have performance heads for street motors?
simemk
Yes I have some heads whit 8mm new valves 39,5/34/5 complete whit new guides , OE springs ,lightened OE retainers ..... 3 angle cut valve seat , cut on all side to be perfect flat ......
simemk
39,5/34,5 -8mm
simemk
Prices?;)
simemk
Head 39,5 /34,5 new valves, new guides, 3 angle cut valve seat whit springs (new) retainers .... cc500e
valves is lightened polished, valve springs platform is cut for more installed height on v.springs ,retainers is lightened ...
Head in exchange?
simemk
No
berserker0815
Beitrag von berserker0815 »
Hey Sime.
Your webside isn`t working...can you place a list of parts you like to sell?
Thanks, Ralf
Walter Röhrl
simemk
I just open ???? I like sale all what I have for engine and short ratio gears complete or set of gears , LSD,lifters top flat,racing valves ,guides...
I have http://simefiatpower.tripod.com/parts_c ... e.html...I have and OE new parts .
Racing parts offer:
SOHC - ENGINES - FIAT 128, RITMO-60/65/75, X1/9, UNO, TIPO, YUGO, ZASTAVA101, TOFAS…
A: ENGINE HI - PERF- PARTS
B: GEARBOX PARTS
C: O.E. NEW PARTS
E: USED RACING PARTS/CARS
F: PRICES
A: ENIGINE HI-PERF- PARTS
A-1 PISTONS O.E.(BORGO,MAHLE…) OPENED VALVE POCKET, BALANCED (SORTHENET-DEPEND OF APLICATION)
80 mm TO 87 mm – FOR 1116 ,1290,1301,1372,1491,1580 ccm
A-2 RODS.OE – NEW LIGHTENED – POLISHED BALACED END TO END SET OF 4
FOR 1116 AND 1290/1301
FOR 1372 ,1491,1600
A-3 FLYWHEEL LIGHTENED BALANCED USE O.E ,dim. CLUTCH + COWER
a - 1116/1300 (180mm) weight cc 4,5 kg
b - Same from steel cc 3.5 kg
c - 1372 (TIPO) cc 5-5.2 kg
d - 1581 (TIPO) cc 4.8 kg
A-4 a-CRANK new 1.1/1.3 55.5 mm lightened, balanced,
polished, doweled for flywheel weight cc 9.2 kg
b- used (std or 0.10 regrind ) opened cleaned inside balanced …
c- used (std or 0.10 regrind) for 1.5 (63.9mm stroke) balanced ,polished doweled….9,2kg…
d crank new for 1.6 – 67.4 mm lightened, polished, balanced , doweled weight cc 8/8.2 kg
e used 67,4mm new lightened balanced polished…
A-5 HEADS 1.1/1.3 with O.E. 36/31mm –valves ,
Lightened….
opened throats ,enlarged ports , new guides 3 angle seat cut come whit springs + lightened steel retainers, cc 22-23ccm (or other)
A-6 HEADS 1.3/.1.5/1.6 instaled whit valves 40/35mm – 7mm from 21-4N steel chromed steam , opened ports new seats 3 angle cut, come whit spring ( good for 9000+ ) end steel retainers.Whit ex bronze guides , ph iron inlet guides....
A-6RTi like A-5 – but with “ Iskyâ€
http://simefiatpower.tripod.com/ is ok.... But in your profile you wrote http://www.simefiatpower.tripod.com/
simemk
Sorry . I changed .
