I have available A few different grinds OF cams  suit sohc Fiats. They are manufactured by A company called Pittatore in Italy, who actually make cams for Alquati!
They are all new cams, not reground, and are available in either cast iron or nitrided steel.
CAM SOHC 40/80 9.70 (IRON) grind NUMBER 005
CAM SOHC 33/73 9.40 (IRON) grind number12B
CAM SOHC 24/68 9.35 (IRON) A CoPy OF the std euro grind
CAM SOHC 40/80 10.3 (nitrided steel) grind NUMBER 77
CAM SOHC 35/75 10.2 (nitrided steel) grind NUMBER 86
CAM SOHC 42/82 10.6 (nitrided steel) grind NUMBER 87
the nitrided steel cams have the
spline fitted to drive distributors from the rear OF the
cam.
The nitrided cams are 550$aus and the cast iron cams
 400$aus.
I can ship anywhere into the world, buyer pays freight, any questions, please email ME on
SCecchele@bigpond.com
SteveC (The Fiat Factory)
please excuse the poor English, this message doesn't appear as I have typed it, something (probably) to DO with the translation engine (bablefish)
						new performance camshafts SOHC Fiat
				fiatfactory
- 2Slow4You
 - Hat sich bedankt: 1 Mal
Hi Steve
and welcome to the german Forum :fadein:
Und jetzt nochmal ne Kurzübersetzung:
Hier gibts nagelneue Nockenwellen (kein abgedrehten, welche zusätzliche Plättchen etc benötigen) normal und nitriert. Die nietrierten haben zusätzlich die Möglichkeit den Verteiler an der Nockenwelle anzutreiben.
