uno turbo engine in X1/9
eucalipt
Beitrag von eucalipt »
I mount the uno turbo engine into X1/9 , keepng the uno turbo electric wire loom.
Now I want to switch back to original X1/9 electrical wire loom.
Is anyone here who have put a uno turbo engine using the original x1/9 electrical wire loom ?
any1 knows wich wire where to connect so the engine will work good ?
Thanks
PS> sorry i don;t speak german .....yet :)
Hi, better use the Turboelectric with the original X Machine.
I have a Turbo X, and after a Motorcrash i put the org. X Machine with the Turbo electric and it works very good.
eucalipt
hmmm
My X originally carbed ...... engine works on carburator. I want to get out the uno turbo electric wire loom, because of the too manny soldering and adapters.
I read on some post, there are only 6 wires from uno turbo to connect on x1/9 electrical wire loom.
Maybe you can describe , put some photos of exactly what you did ?
Thanks , OVI
Re: hmmm
eucalipt hat geschrieben: I read on some post, there are only 6 wires from uno turbo to connect on x1/9 electrical wire loom.
Ovi, this refers to an X1/9 with (factory) fuel injection. There the connection should be quite easy (not done myself) as it already contains electric fuel pump, etc.
eucalipt
ahhhh
then it means I'll have some work to do to figure it out ........
let's hope I'll succeed :P
anyways, I am open to any Advice , thanks
Re: hmmm
Pauer hat geschrieben:
Not really...
The Wire from the Turbo and X Injection are "Stand alone"...
On the Turbo Wire you have to connect:
Power
Minus
RPM (Drehzahlmesser fällt mir grad nicht ein... :oops: )
Fuelpump
The Rest is "intern" connectet.
The only "Problem" is the Tank (heist das nicht Panzer??? Aber Babelfish meint auch "Tank" zum Tank... :roll: )
The Connection for the Pump is on the upper Side at the carbed Version (and 6mm hose) and lower Side at the i.E. Version (10mm hose).
An die, die Englisch können... Ist das einigermaßen korrekt so geschrieben??
eucalipt
english is corect
I know a few words in german too, so i think i got it . Next week I'll start doing it.
Thanks for the info
Installing he turbo engine in a 1500cc MPI should be very easy.
When you want you can use the MPI block because the CR is 8.8:1.
A little bit more fuel and the engine should run fine.
Fuel pump etc. you can use from MPI.
You only have to change the exhaust manifold, you can use the inlet manifold from MPI (bigger throttle body).
But fuel injectors from MPI you can't use with the Turbo ECU because the resistance of the MPI injectors is lower and kill's the ECU...
Ignition distributor you can use the 1372cc Turbo distributor, same position like MPI.
Regards
eucalipt
Good news ,
I have buyed from USA a complete eletrical and fusebox made in 1988 in great condition, so now i will have electrical from a injection engine, maybe it will be easyer to fit the uno turbo engine inside.
If anyone have some specific detailed advice , maybe photos included, I will be very happy to follow the instruction.
THANK YOU ALL !
eucalipt
question about conversion
I have buyed a FI wire harness instalation , all wires , what I have noticed was that the black box don;t fit on the wire connector, the air flow meter connector is not same ....what should I do ? keep the x1/9 FI black box and air flow meter mounted on uno turbo engine ?
